Giriş
This guide will instruct you to replace the effect button circuit board on the RCA CC310.
Neye ihtiyacın var
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Unplug the two cables on the bottom of the effect button circuit board.
Unplug the cable at the top left side of the motherboard.
Bir başkası bu kılavuzu tamamladı.
