Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will instruct you to replace the effect button circuit board on the RCA CC310.
  1. Remove the six 7.9mm Phillips #0 screws on the back and bottom. Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. Remove 5.8mm Phillips #1 screw from the side button panel. Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  4. Pry along the seam on the top side near the buttons with a spudger. Pry along the seam on the top side near the buttons with a spudger.
    • Pry along the seam on the top side near the buttons with a spudger.
  5. Pull the left panel away from the rest of the camcorder. Unplug the red speaker cable located at the rear of the device.
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  6. Unplug the two cables on the bottom of the effect button circuit board. Unplug the cable at the top left side of the motherboard.
    • Unplug the two cables on the bottom of the effect button circuit board.
    • Unplug the cable at the top left side of the motherboard.
  7. Pull the plastic tabs away from the circuit board. Pull the board away from the camcorder. Use a spudger to help push the mini-circuit board away from the camcorder at the same time.
    • Pull the plastic tabs away from the circuit board.
    • Pull the board away from the camcorder.
    • Use a spudger to help push the mini-circuit board away from the camcorder at the same time.
    • Unplug the cable in the middle of the effects board.
Sonuç
Oliver Adams
620 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G20
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,478
