Ana içeriğe geç
RCA CC310 Onboard Microphone Replacement
Neye ihtiyacın var
  1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: adım 1, 2 resimden 1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: adım 1, 2 resimden 2.
    • Lift the metal flap and slide the viewfinder off to the right.
  2. RCA CC310 Onboard Microphone Replacement: adım 2, 3 resimden 1. RCA CC310 Onboard Microphone Replacement: adım 2, 3 resimden 2. RCA CC310 Onboard Microphone Replacement: adım 2, 3 resimden 3.
    • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable is connected to the viewfinder.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Onboard Microphone Replacement: adım 3, 2 resimden 1. RCA CC310 Onboard Microphone Replacement: adım 3, 2 resimden 2.
    • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up.
  4. RCA CC310 Onboard Microphone Replacement: adım 4, 2 resimden 1. RCA CC310 Onboard Microphone Replacement: adım 4, 2 resimden 2.
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  5. RCA CC310 Onboard Microphone Replacement: adım 5, 1 resimden 1.
    • Turn the microphone circuit board over.
    • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
  6. RCA CC310 Onboard Microphone Replacement: adım 6, 1 resimden 1.
    • Desolder the metal protective housing using a soldering iron.
    • Desolder the microphone and replace it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Oliver Adams
629 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G20
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 912
