Ana içeriğe geç
RCA CC310 Onboard Speaker Replacement
Neye ihtiyacın var
  1. RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: adım 1, 2 resimden 1. RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: adım 1, 2 resimden 2.
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Onboard Speaker Replacement: adım 2, 2 resimden 1. RCA CC310 Onboard Speaker Replacement: adım 2, 2 resimden 2.
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Onboard Speaker Replacement: adım 3, 2 resimden 1. RCA CC310 Onboard Speaker Replacement: adım 3, 2 resimden 2.
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Onboard Speaker Replacement: adım 4, 2 resimden 1. RCA CC310 Onboard Speaker Replacement: adım 4, 2 resimden 2.
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Onboard Speaker Replacement, Onboard Speaker: adım 5, 2 resimden 1. RCA CC310 Onboard Speaker Replacement, Onboard Speaker: adım 5, 2 resimden 2.
    • Unplug the red cable connecting the speaker to the motherboard.
  6. RCA CC310 Onboard Speaker Replacement: adım 6, 2 resimden 1. RCA CC310 Onboard Speaker Replacement: adım 6, 2 resimden 2.
    • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
    • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
  7. RCA CC310 Onboard Speaker Replacement: adım 7, 1 resimden 1.
    • Break the plastic pieces holding the cable to the panel.
    • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
  8. RCA CC310 Onboard Speaker Replacement: adım 8, 3 resimden 1. RCA CC310 Onboard Speaker Replacement: adım 8, 3 resimden 2. RCA CC310 Onboard Speaker Replacement: adım 8, 3 resimden 3.
    • Glue the new speaker to the panel.
    • Plug the cable back into the motherboard.
Sonuç
Oliver Adams
629 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G20
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 995
