Ana içeriğe geç
RCA CC310 Viewfinder Replacement
Neye ihtiyacın var
    1. RCA CC310 Viewfinder Replacement, Viewfinder: adım 1, 2 resimden 1. RCA CC310 Viewfinder Replacement, Viewfinder: adım 1, 2 resimden 2.
      • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
      • Pushing the viewfinder assembly to the right makes lifting the flap easier.
      • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
      FixBot'a Sor
      Yorum Ekle
    2. RCA CC310 Viewfinder Replacement: adım 2, 3 resimden 1. RCA CC310 Viewfinder Replacement: adım 2, 3 resimden 2. RCA CC310 Viewfinder Replacement: adım 2, 3 resimden 3.
      • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
      • Lift the plastic where the cable connects off of the viewfinder assembly.
      • Disconnect the cable inside by pulling it apart.
      FixBot'a Sor
      Yorum Ekle
    3. RCA CC310 Viewfinder Replacement: adım 3, 2 resimden 1. RCA CC310 Viewfinder Replacement: adım 3, 2 resimden 2.
      • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
      • Lift the viewfinder plastic assembly up and remove.
      FixBot'a Sor
      Yorum Ekle
    4. RCA CC310 Viewfinder Replacement: adım 4, 1 resimden 1.
      • Flip back the viewfinder access tab.
      • Unscrew the 7.0mm ph #0 screw next to the mirror.
      FixBot'a Sor
      Yorum Ekle
    5. RCA CC310 Viewfinder Replacement: adım 5, 3 resimden 1. RCA CC310 Viewfinder Replacement: adım 5, 3 resimden 2. RCA CC310 Viewfinder Replacement: adım 5, 3 resimden 3.
      • Lift off both sides of the plastic assembly.
      • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
      FixBot'a Sor
      Yorum Ekle
    6. RCA CC310 Viewfinder Replacement: adım 6, 2 resimden 1. RCA CC310 Viewfinder Replacement: adım 6, 2 resimden 2.
      • Lift the microphone circuit board straight up.
      • Unclip the cable connected to the circuit board.
      FixBot'a Sor
      Yorum Ekle
    7. RCA CC310 Viewfinder Replacement: adım 7, 3 resimden 1. RCA CC310 Viewfinder Replacement: adım 7, 3 resimden 2. RCA CC310 Viewfinder Replacement: adım 7, 3 resimden 3.
      • Lift plastic housing and guide the wires from underneath.
      • Lift out the entire circuit board and viewfinder.
      • Replace entire circuit board and viewfinder assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Oliver Adams
629 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-20, Amido Winter 2011 Cal Poly, Team 5-20, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G20
4 Üyeler
21 adet Kılavuz yazıldı
1Rehber Yorum
do you know where i can find a relacement one of these parts
Connor Byrley - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 51
Her zaman: 2,956
