Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
Unscrew the 7mm ph#0 screw on the underside where the cable connects.
Lift the plastic where the cable connects off of the viewfinder assembly.
Disconnect the cable inside by pulling it apart.
Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
Lift the viewfinder plastic assembly up and remove.
Flip back the viewfinder access tab.
Unscrew the 7.0mm ph #0 screw next to the mirror.
Lift the microphone circuit board straight up.
Unclip the cable connected to the circuit board.
Lift plastic housing and guide the wires from underneath.
Lift out the entire circuit board and viewfinder.
Replace entire circuit board and viewfinder assembly.
