Ana içeriğe geç
RCA Lyra X2400 USB port replacement
Neye ihtiyacın var
  1. RCA Lyra X2400 USB port replacement, Screen: adım 1, 2 resimden 1. RCA Lyra X2400 USB port replacement, Screen: adım 1, 2 resimden 2.
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. RCA Lyra X2400 USB port replacement: adım 2, 2 resimden 1. RCA Lyra X2400 USB port replacement: adım 2, 2 resimden 2.
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. RCA Lyra X2400 USB port replacement: adım 3, 3 resimden 1. RCA Lyra X2400 USB port replacement: adım 3, 3 resimden 2. RCA Lyra X2400 USB port replacement: adım 3, 3 resimden 3.
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  4. RCA Lyra X2400 USB port replacement, Motherboard: adım 4, 2 resimden 1. RCA Lyra X2400 USB port replacement, Motherboard: adım 4, 2 resimden 2.
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  5. RCA Lyra X2400 USB port replacement, USB in/out: adım 5, 2 resimden 1. RCA Lyra X2400 USB port replacement, USB in/out: adım 5, 2 resimden 2.
    • Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
    • Start using solder/desolder tools to remove the USB in/out.
    • Once removed replace it with the new working USB in/out.
    • Use the soldering tools to reattach the component back to the main logic board.
Sonuç
Joseph Goodwin
1 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-3, Regan Spring 2013 Cal Poly, Team 17-3, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 235
