Ana içeriğe geç
RCA Lyra X2400 flash card reader replacement
Neye ihtiyacın var
  1. RCA Lyra X2400 flash card reader replacement, Battery: adım 1, 3 resimden 1. RCA Lyra X2400 flash card reader replacement, Battery: adım 1, 3 resimden 2. RCA Lyra X2400 flash card reader replacement, Battery: adım 1, 3 resimden 3.
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 flash card reader replacement, Screen: adım 2, 2 resimden 1. RCA Lyra X2400 flash card reader replacement, Screen: adım 2, 2 resimden 2.
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 flash card reader replacement: adım 3, 2 resimden 1. RCA Lyra X2400 flash card reader replacement: adım 3, 2 resimden 2.
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 flash card reader replacement: adım 4, 3 resimden 1. RCA Lyra X2400 flash card reader replacement: adım 4, 3 resimden 2. RCA Lyra X2400 flash card reader replacement: adım 4, 3 resimden 3.
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 flash card reader replacement, Motherboard: adım 5, 2 resimden 1. RCA Lyra X2400 flash card reader replacement, Motherboard: adım 5, 2 resimden 2.
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  6. RCA Lyra X2400 flash card reader replacement, Compact Flash Card: adım 6, 2 resimden 1. RCA Lyra X2400 flash card reader replacement, Compact Flash Card: adım 6, 2 resimden 2.
    • Locate the compact flash card slot on the logic board. For assistance on locating this component look at the picture to the left.
    • Use soldering/desoldering tools to remove the compact flash card.
    • Replace compact flash card and use soldering tools to complete the replacement.
Sonuç
Joseph Goodwin
1 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-3, Regan Spring 2013 Cal Poly, Team 17-3, Regan Spring 2013 üyesi
CPSU-REGAN-S13S17G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 260
