Ana içeriğe geç
RCA Maven Pro 11 Battery Replacement
Neye ihtiyacın var
  1. RCA Maven Pro 11 Battery Replacement, Cover: adım 1, 2 resimden 1. RCA Maven Pro 11 Battery Replacement, Cover: adım 1, 2 resimden 2.
    • Remove all the 8 mm Phillips head screws on the side and back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. RCA Maven Pro 11 Battery Replacement: adım 2, 2 resimden 1. RCA Maven Pro 11 Battery Replacement: adım 2, 2 resimden 2.
    • Pry off the cover by sticking a wedge in between the screen and the cover.
    • Be careful with the plastic because it can easily break.
    • Once the cover is partly removed, use your hands to take off the rest of the cover.
    FixBot'a Sor
    Yorum Ekle
  3. RCA Maven Pro 11 Battery Replacement, Battery: adım 3, 2 resimden 1. RCA Maven Pro 11 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Pull out the pins circled in the picture.
    • These pins can be removed by hand. Just pull on them individually.
    FixBot'a Sor
    Yorum Ekle
  4. RCA Maven Pro 11 Battery Replacement: adım 4, 1 resimden 1.
    • Use the opening tools to peel the battery off of the panel.
    • The glue is located in the corners.
    • Do not bend or puncture the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
My husband installed my new battery in my ex's haven pro tablet and when we turned it on it said battery charger 65%. I then turned it back off to co time charging to 100% it when I checked in a few hours, the battery level dropped to 20% and I cannot get it to recharge. It is now completely dead and will not take a charge what should I do?
Carol tyciak - Yanıt Paylaş
My husband installed a new battery into my RCA Maven Pro tablet and when we turned it on, it showed 65% battery life. I then turned it off to continue to charge to 100%. When I checked it in about 4 hours, it was down to 20% and now it is depleted completely and I can't get it to recharge. What should I do now?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 1,958
