Ana içeriğe geç
RCA Pro10 Edition Camera Replacement
Neye ihtiyacın var
  1. RCA Pro10 Edition Camera Replacement, Speaker: adım 1, 2 resimden 1. RCA Pro10 Edition Camera Replacement, Speaker: adım 1, 2 resimden 2.
    • Using a separating tool, look for a seam in the plastic casing that looks most accessible.
    • Use the prying tool to separate the front and back casing, working your way around the perimeter.
    • Utilize a card tool or a pick to assist in keeping the case separated.
    • To reassemble the device simply align the two casing halves and pinch to snap together or press down on the edges while the device in on a table.
  2. RCA Pro10 Edition Camera Replacement: adım 2, 1 resimden 1.
    • Flip over the back of the device while keeping it close to the front, the speaker is attached to it.
    • Remove the yellow tape securing the speaker to the back casing.
  3. RCA Pro10 Edition Camera Replacement: adım 3, 2 resimden 1. RCA Pro10 Edition Camera Replacement: adım 3, 2 resimden 2.
    • Use the separating tool to pry the speaker from its surface.
    • Use caution when removing the speaker, you may damage the screen.
    • Cut or desolder the wires to replace or repair the speaker.
  4. RCA Pro10 Edition Camera Replacement, Camera: adım 4, 3 resimden 1. RCA Pro10 Edition Camera Replacement, Camera: adım 4, 3 resimden 2. RCA Pro10 Edition Camera Replacement, Camera: adım 4, 3 resimden 3.
    • Using a P00 Phillips screwdriver, remove the three screws securing the black plastic camera housing and remove it.
    • Peel back the beige tape while holding down the camera ribbon cable to prevent tears
  5. RCA Pro10 Edition Camera Replacement: adım 5, 2 resimden 1. RCA Pro10 Edition Camera Replacement: adım 5, 2 resimden 2.
    • Lift the locking tab that is securing the camera ribbon cable.
    • Slide the ribbon cable out from the connector and remove from casing.
Sonuç
Dayne Russell
404 İtibar
4 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 1-1, Prince Winter 2015 Pasco Hernando, Team 1-1, Prince Winter 2015 üyesi
PHSC-PRINCE-W15S1G1
6 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 473
