Ana içeriğe geç
RCA RCR8622 Buttons Replacement
Neye ihtiyacın var
  1. RCA RCR8622 Buttons Replacement, Speaker: adım 1, 3 resimden 1. RCA RCR8622 Buttons Replacement, Speaker: adım 1, 3 resimden 2. RCA RCR8622 Buttons Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 Buttons Replacement: adım 2, 3 resimden 1. RCA RCR8622 Buttons Replacement: adım 2, 3 resimden 2. RCA RCR8622 Buttons Replacement: adım 2, 3 resimden 3.
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 Buttons Replacement: adım 3, 2 resimden 1. RCA RCR8622 Buttons Replacement: adım 3, 2 resimden 2.
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
  4. RCA RCR8622 Buttons Replacement, LCD Screen: adım 4, 3 resimden 1. RCA RCR8622 Buttons Replacement, LCD Screen: adım 4, 3 resimden 2. RCA RCR8622 Buttons Replacement, LCD Screen: adım 4, 3 resimden 3.
    • Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver.
    • Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
  5. RCA RCR8622 Buttons Replacement: adım 5, 3 resimden 1. RCA RCR8622 Buttons Replacement: adım 5, 3 resimden 2. RCA RCR8622 Buttons Replacement: adım 5, 3 resimden 3.
    • Lift the motherboard out of the interior of the device.
    • Remove the screen section of the device by lifting upward on the circuit it is connected to by sliding it upwards.
    • Both sections will be connected with a ribbon connection.
  6. RCA RCR8622 Buttons Replacement: adım 6, 3 resimden 1. RCA RCR8622 Buttons Replacement: adım 6, 3 resimden 2. RCA RCR8622 Buttons Replacement: adım 6, 3 resimden 3.
    • Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen.
    • Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
  7. RCA RCR8622 Buttons Replacement: adım 7, 2 resimden 1. RCA RCR8622 Buttons Replacement: adım 7, 2 resimden 2.
    • Lift the screen upward, taking care not to allow the films below it to fall out.
  8. RCA RCR8622 Buttons Replacement, Buttons: adım 8, 3 resimden 1. RCA RCR8622 Buttons Replacement, Buttons: adım 8, 3 resimden 2. RCA RCR8622 Buttons Replacement, Buttons: adım 8, 3 resimden 3.
    • Identify which button needs to be changed out. There will be lables on the board indicating functionality of each button.
    • Flip the board over and find the button by the circles on the board.
    • Solder the 2 pins off the button and pinch the top of the button on the other side to pull off.
Sonuç
Josh Excell
449 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S6-G5, Baechle Spring 2018 IUPUI, Team S6-G5, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S6G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 269
