Neye ihtiyacın var
Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
2 farklı kişi bu kılavuzu tamamladı.
