Giriş
In order to replace a broken front or rear camera, you will need to follow this guide. There are several steps and you will need to be careful when taking apart this device.
Neye ihtiyacın var
Make sure the device is off to reduce the chance of an electrical shock. To turn off the device, press and hold the power button.
Use a Phillips #00 Screwdriver to unscrew the 4mm (5/32 in.) screws from the back cover of the tablet.
Attached to the motherboard you will see two orange ribbons connected to black tabs.
Using both hands, place your thumbs gently on the black tab attached to the top and gently lift it.
Proceed to slide the orange colored ribbon out from underneath until it is detached from the black tab.
Bir başkası bu kılavuzu tamamladı.
