Ana içeriğe geç
RCA RCT6203W46 Rear Speaker Replacement
Neye ihtiyacın var
  1. RCA RCT6203W46 Rear Speaker Replacement, Rear Speaker: adım 1, 2 resimden 1. RCA RCT6203W46 Rear Speaker Replacement, Rear Speaker: adım 1, 2 resimden 2.
    • Remove these four 4 mm Phillips #00 screws.
  2. RCA RCT6203W46 Rear Speaker Replacement: adım 2, 2 resimden 1. RCA RCT6203W46 Rear Speaker Replacement: adım 2, 2 resimden 2.
    • Run a spudger tool around the edge of the screen to loosen it and begin to pry upward.
    • The screen will be able to be removed once you see it pop up like it has in the photo.
    • There are wires attached to the back cover and screen so be careful not to pull them apart.
  3. RCA RCT6203W46 Rear Speaker Replacement: adım 3, 3 resimden 1. RCA RCT6203W46 Rear Speaker Replacement: adım 3, 3 resimden 2. RCA RCT6203W46 Rear Speaker Replacement: adım 3, 3 resimden 3.
    • With a soldering iron, remove the wires from the circuit board.
    • Due to the size of the wires, tweezers may be necessary.
  4. RCA RCT6203W46 Rear Speaker Replacement: adım 4, 1 resimden 1.
    • Use a metal spudger to pry out the speakers from its housing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nicholas Alexander
318 İtibar
2 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-2, Oliver Fall 2016 UC Davis, Team 1-2, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G2
5 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 356
