Giriş
In this guide, you will learn how to replace the motherboard on a RCA RCT6272W23.
Neye ihtiyacın var
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Use a soldering iron to remove the soldered connections on the motherboard
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
i need to know everything there is about the motherboard. an tablet. images, info etc
