Giriş
In this guide, you will learn how to replace the motherboard on a RCA RCT6272W23.
Neye ihtiyacın var
Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
Use a soldering iron to remove the soldered connections on the motherboard
Unsoldering the motherboard is not necessary to replace the display. Once cables are disconnected from the mother board, the motherboard and the battery should remove as one complete piece.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
i need to know everything there is about the motherboard. an tablet. images, info etc
