Ana içeriğe geç
Giriş
  • This guide might be of use if the battery life of your device has degraded over time.
  • HAZARDS: Don't use heat to remove the adhesive of the battery because it can potentially cause a fire.
  1. Remove nine 4.8mm screws around the case with a JIS #00 screwdriver. Remove nine 4.8mm screws around the case with a JIS #00 screwdriver. Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
  3. Remove cover completely. Remove cover completely. Remove cover completely.
    • Remove cover completely.
  4. Disconnect battery cable from the motherboard. Disconnect battery cable from the motherboard. Disconnect battery cable from the motherboard.
    • Disconnect battery cable from the motherboard.
  5. Pull the thin black keyboard connector off and set it aside. Pull the thin black keyboard connector off and set it aside. Pull the thin black keyboard connector off and set it aside.
    • Pull the thin black keyboard connector off and set it aside.
  6. Disconnect the thick black band (bus) using a plastic opening tool or fingernail. Disconnect the thick black band (bus) using a plastic opening tool or fingernail. Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. Use nylon spudger tool or plastic card to separate battery from the case.
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. Carefully peel off the battery. Carefully peel off the battery. Carefully peel off the battery.
    • Carefully peel off the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Akitaka Hashimoto
360 İtibar
2 adet Kılavuz yazıldı
Takım
IUPUI, Team S3-G2, Harley Spring 2018 IUPUI, Team S3-G2, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S3G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 30
Son 30 Gün: 105
Her zaman: 1,561
