Ana içeriğe geç
RCA RCT6303W87 Speaker Replacement
Neye ihtiyacın var
  1. RCA RCT6303W87 Speaker Replacement, Battery: adım 1, 3 resimden 1. RCA RCT6303W87 Speaker Replacement, Battery: adım 1, 3 resimden 2. RCA RCT6303W87 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. RCA RCT6303W87 Speaker Replacement: adım 2, 1 resimden 1.
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
  3. RCA RCT6303W87 Speaker Replacement: adım 3, 3 resimden 1. RCA RCT6303W87 Speaker Replacement: adım 3, 3 resimden 2. RCA RCT6303W87 Speaker Replacement: adım 3, 3 resimden 3.
    • Remove cover completely.
  4. RCA RCT6303W87 Speaker Replacement: adım 4, 3 resimden 1. RCA RCT6303W87 Speaker Replacement: adım 4, 3 resimden 2. RCA RCT6303W87 Speaker Replacement: adım 4, 3 resimden 3.
    • Disconnect battery cable from the motherboard.
  5. RCA RCT6303W87 Speaker Replacement: adım 5, 3 resimden 1. RCA RCT6303W87 Speaker Replacement: adım 5, 3 resimden 2. RCA RCT6303W87 Speaker Replacement: adım 5, 3 resimden 3.
    • Pull the thin black keyboard connector off and set it aside.
  6. RCA RCT6303W87 Speaker Replacement: adım 6, 3 resimden 1. RCA RCT6303W87 Speaker Replacement: adım 6, 3 resimden 2. RCA RCT6303W87 Speaker Replacement: adım 6, 3 resimden 3.
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. RCA RCT6303W87 Speaker Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. RCA RCT6303W87 Speaker Replacement: adım 8, 3 resimden 1. RCA RCT6303W87 Speaker Replacement: adım 8, 3 resimden 2. RCA RCT6303W87 Speaker Replacement: adım 8, 3 resimden 3.
    • Carefully peel off the battery.
  9. RCA RCT6303W87 Speaker Replacement, Speaker: adım 9, 3 resimden 1. RCA RCT6303W87 Speaker Replacement, Speaker: adım 9, 3 resimden 2. RCA RCT6303W87 Speaker Replacement, Speaker: adım 9, 3 resimden 3.
    • Disconnect the speaker cord from the motherboard.
  10. RCA RCT6303W87 Speaker Replacement: adım 10, 3 resimden 1. RCA RCT6303W87 Speaker Replacement: adım 10, 3 resimden 2. RCA RCT6303W87 Speaker Replacement: adım 10, 3 resimden 3.
    • Use the plastic spudger to slide the speaker out.
Sonuç
Akitaka Hashimoto
525 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Spring 2018 IUPUI, Team S3-G2, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S3G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 445
