Giriş
After noticing your battery life deteriorate or you notice a bulge in the back of the device, it is time to replace the battery. In this guide, you will be removing the following parts:
- 1. Back Cover
- 2. Battery
Neye ihtiyacın var
Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
The new wires must be soldered back into place on the motherboard at the original location.
For tips on soldering techniques, see this Soldering Guide
Bir başkası bu kılavuzu tamamladı.
