Ana içeriğe geç
RCA RCT6773W22 Battery Replacement
Neye ihtiyacın var
  1. RCA RCT6773W22 Battery Replacement, Battery: adım 1, 2 resimden 1. RCA RCT6773W22 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: adım 2, 3 resimden 1. RCA RCT6773W22 Battery Replacement: adım 2, 3 resimden 2. RCA RCT6773W22 Battery Replacement: adım 2, 3 resimden 3.
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
    My tablet gets hot to were it smells melts and burns me
    KACHINA Price - Yanıt
    Yikes! It sounds like your battery might be overheating. Try opening up the tablet and check the condition of the battery. It will probably need to be replaced.
    Kelsea Weber - Yanıt
  3. RCA RCT6773W22 Battery Replacement: adım 3, 3 resimden 1. RCA RCT6773W22 Battery Replacement: adım 3, 3 resimden 2. RCA RCT6773W22 Battery Replacement: adım 3, 3 resimden 3.
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelsea Weber
19.857 İtibar
32 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.732 adet Kılavuz yazıldı
Bir Yorum
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 3,828
