Ana içeriğe geç
RCA RCT6773W22 Motherboard Replacement
Neye ihtiyacın var
  1. RCA RCT6773W22 Motherboard Replacement, Battery: adım 1, 2 resimden 1. RCA RCT6773W22 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Motherboard Replacement: adım 2, 3 resimden 1. RCA RCT6773W22 Motherboard Replacement: adım 2, 3 resimden 2. RCA RCT6773W22 Motherboard Replacement: adım 2, 3 resimden 3.
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Motherboard Replacement: adım 3, 3 resimden 1. RCA RCT6773W22 Motherboard Replacement: adım 3, 3 resimden 2. RCA RCT6773W22 Motherboard Replacement: adım 3, 3 resimden 3.
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Motherboard Replacement, Speaker: adım 4, 3 resimden 1. RCA RCT6773W22 Motherboard Replacement, Speaker: adım 4, 3 resimden 2. RCA RCT6773W22 Motherboard Replacement, Speaker: adım 4, 3 resimden 3.
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
  5. RCA RCT6773W22 Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. RCA RCT6773W22 Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. RCA RCT6773W22 Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Use the spudger to lift up the black tab on all three ZIF connectors.
    • Use tweezers to remove the ribbon cables from the zift connectors.
  6. RCA RCT6773W22 Motherboard Replacement: adım 6, 1 resimden 1.
    • Use Phillips #000 screwdriver to remove the three 3mm screws on the motherboard.
  7. RCA RCT6773W22 Motherboard Replacement: adım 7, 2 resimden 1. RCA RCT6773W22 Motherboard Replacement: adım 7, 2 resimden 2.
    • Use a spudger or plastic opening tool to lift up the motherboard.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kelsea Weber
19.867 İtibar
32 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,968
