Ana içeriğe geç
RCA RCT6773W22 Speaker Replacement
Neye ihtiyacın var
  1. RCA RCT6773W22 Speaker Replacement, Battery: adım 1, 2 resimden 1. RCA RCT6773W22 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Speaker Replacement: adım 2, 3 resimden 1. RCA RCT6773W22 Speaker Replacement: adım 2, 3 resimden 2. RCA RCT6773W22 Speaker Replacement: adım 2, 3 resimden 3.
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Speaker Replacement: adım 3, 3 resimden 1. RCA RCT6773W22 Speaker Replacement: adım 3, 3 resimden 2. RCA RCT6773W22 Speaker Replacement: adım 3, 3 resimden 3.
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Speaker Replacement, Speaker: adım 4, 3 resimden 1. RCA RCT6773W22 Speaker Replacement, Speaker: adım 4, 3 resimden 2. RCA RCT6773W22 Speaker Replacement, Speaker: adım 4, 3 resimden 3.
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kelsea Weber
19.864 İtibar
32 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.767 adet Kılavuz yazıldı
Bir Yorum
Where can I buy a replacement speaker?
laubd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,087
