Giriş
This guide will illustrate how to remove the speaker.
Neye ihtiyacın var
Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
Desolder the wire connected from the speaker to the motherboard.
Pry the speaker from the casing with a plastic opening tool.
Bir başkası bu kılavuzu tamamladı.
