Ana içeriğe geç
RCA RP3715A Motherboard Replacement
Neye ihtiyacın var
  1. RCA RP3715A Motherboard Replacement, Getting inside the device.: adım 1, 1 resimden 1.
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  2. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: adım 2, 3 resimden 1. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: adım 2, 3 resimden 2. RCA RP3715A Motherboard Replacement, Relieve extension cord tension.: adım 2, 3 resimden 3.
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  3. RCA RP3715A Motherboard Replacement: adım 3, 2 resimden 1. RCA RP3715A Motherboard Replacement: adım 3, 2 resimden 2.
    • Using flathead screwdriver undo the release tabs.
  4. RCA RP3715A Motherboard Replacement: adım 4, 3 resimden 1. RCA RP3715A Motherboard Replacement: adım 4, 3 resimden 2. RCA RP3715A Motherboard Replacement: adım 4, 3 resimden 3.
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  5. RCA RP3715A Motherboard Replacement: adım 5, 2 resimden 1. RCA RP3715A Motherboard Replacement: adım 5, 2 resimden 2.
    • Pry open both tabs to remove the topside of the clock.
  6. RCA RP3715A Motherboard Replacement, Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  7. RCA RP3715A Motherboard Replacement, Detaching the front panel: adım 7, 1 resimden 1.
    • Remove the two 10 mm Phillip's #1 screws.
  8. RCA RP3715A Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the gray panel from the frame.
  9. RCA RP3715A Motherboard Replacement, Unlatch release tabs: adım 9, 3 resimden 1. RCA RP3715A Motherboard Replacement, Unlatch release tabs: adım 9, 3 resimden 2. RCA RP3715A Motherboard Replacement, Unlatch release tabs: adım 9, 3 resimden 3.
    • The two latches located in the picture will help take off the display.
    • Remove the display.
  10. RCA RP3715A Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. RCA RP3715A Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
    • asd
  11. RCA RP3715A Motherboard Replacement, Removing the top part of motherboard: adım 11, 1 resimden 1.
    • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
  12. RCA RP3715A Motherboard Replacement, Removing the side part of motherboard: adım 12, 1 resimden 1.
    • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
  13. RCA RP3715A Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the transformer by pulling back the release tab shown.
  14. RCA RP3715A Motherboard Replacement: adım 14, 1 resimden 1.
    • Pull the battery terminal through the whole shown.
  15. RCA RP3715A Motherboard Replacement, Lift the digital screen: adım 15, 1 resimden 1.
    • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
  16. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: adım 16, 3 resimden 1. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: adım 16, 3 resimden 2. RCA RP3715A Motherboard Replacement, Lift the top piece of motherboard: adım 16, 3 resimden 3.
    • Remove the motherboard from the frame using the illustration shown.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Trowell
222 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-5, Brown Fall 2014 USF Tampa, Team 10-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 546
