Ana içeriğe geç
RCA RP3715A Speaker Replacement
Neye ihtiyacın var
  1. RCA RP3715A Speaker Replacement, Reaching the battery terminal.: adım 1, 2 resimden 1. RCA RP3715A Speaker Replacement, Reaching the battery terminal.: adım 1, 2 resimden 2.
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Speaker Replacement, Replacing the battery: adım 2, 1 resimden 1.
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Speaker Replacement, Getting inside the device.: adım 3, 1 resimden 1.
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Speaker Replacement, Relieve extension cord tension.: adım 4, 3 resimden 1. RCA RP3715A Speaker Replacement, Relieve extension cord tension.: adım 4, 3 resimden 2. RCA RP3715A Speaker Replacement, Relieve extension cord tension.: adım 4, 3 resimden 3.
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Speaker Replacement: adım 5, 2 resimden 1. RCA RP3715A Speaker Replacement: adım 5, 2 resimden 2.
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Speaker Replacement: adım 6, 3 resimden 1. RCA RP3715A Speaker Replacement: adım 6, 3 resimden 2. RCA RP3715A Speaker Replacement: adım 6, 3 resimden 3.
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Speaker Replacement: adım 7, 2 resimden 1. RCA RP3715A Speaker Replacement: adım 7, 2 resimden 2.
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Speaker Replacement, Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Myles Waiters
370 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-5, Brown Fall 2014 USF Tampa, Team 10-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 209
