Giriş
This replacement guide will teach you how to replace a worn speaker. This will ensure the device has quality sound. If the speaker has not fixed the issue there may be an electrical shortage in the device.
Neye ihtiyacın var
Push down on the clip to release pressure. The pull off the plastic cover.
Take out the six screws located on the back of the device.
The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
Three screws are located on the back panel. One is located inside the battery carriage.
Two screws are located on the on the back panel on the bottom left and right side.
Remove the 10 mm Phillip's #1 screw.
Then remove the metal reinforcement.
Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
Bir başkası bu kılavuzu tamamladı.
