Ana içeriğe geç
RCA RP3715A Tuning Wheel Replacement
Neye ihtiyacın var
  1. RCA RP3715A Tuning Wheel Replacement, Reaching the battery terminal.: adım 1, 2 resimden 1. RCA RP3715A Tuning Wheel Replacement, Reaching the battery terminal.: adım 1, 2 resimden 2.
    • Push down on the clip to release pressure. The pull off the plastic cover.
    FixBot'a Sor
  2. RCA RP3715A Tuning Wheel Replacement, Replacing the battery: adım 2, 1 resimden 1.
    • Remove the 9-volt battery from the battery terminal.
    FixBot'a Sor
  3. RCA RP3715A Tuning Wheel Replacement, Getting inside the device.: adım 3, 1 resimden 1.
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
    FixBot'a Sor
  4. RCA RP3715A Tuning Wheel Replacement, Relieve extension cord tension.: adım 4, 3 resimden 1. RCA RP3715A Tuning Wheel Replacement, Relieve extension cord tension.: adım 4, 3 resimden 2. RCA RP3715A Tuning Wheel Replacement, Relieve extension cord tension.: adım 4, 3 resimden 3.
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
    FixBot'a Sor
  5. RCA RP3715A Tuning Wheel Replacement: adım 5, 2 resimden 1. RCA RP3715A Tuning Wheel Replacement: adım 5, 2 resimden 2.
    • Using flathead screwdriver undo the release tabs.
    FixBot'a Sor
  6. RCA RP3715A Tuning Wheel Replacement: adım 6, 3 resimden 1. RCA RP3715A Tuning Wheel Replacement: adım 6, 3 resimden 2. RCA RP3715A Tuning Wheel Replacement: adım 6, 3 resimden 3.
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
    FixBot'a Sor
  7. RCA RP3715A Tuning Wheel Replacement: adım 7, 2 resimden 1. RCA RP3715A Tuning Wheel Replacement: adım 7, 2 resimden 2.
    • Pry open both tabs to remove the topside of the clock.
    FixBot'a Sor
  8. RCA RP3715A Tuning Wheel Replacement, Speaker Replacement: adım 8, 1 resimden 1.
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
    FixBot'a Sor
  9. RCA RP3715A Tuning Wheel Replacement, Motherboard: adım 9, 2 resimden 1. RCA RP3715A Tuning Wheel Replacement, Motherboard: adım 9, 2 resimden 2.
    • asd
    FixBot'a Sor
  10. RCA RP3715A Tuning Wheel Replacement, Removing the top part of motherboard: adım 10, 1 resimden 1.
    • Remove the top 5 10mm Phillips #1 screws holding the top part of the motherboard
    FixBot'a Sor
  11. RCA RP3715A Tuning Wheel Replacement, Removing the side part of motherboard: adım 11, 1 resimden 1.
    • Remove the 5 10mm Phillip's #1 screws that holding side part of the motherboard
    FixBot'a Sor
  12. RCA RP3715A Tuning Wheel Replacement: adım 12, 1 resimden 1.
    • Remove the transformer by pulling back the release tab shown.
    FixBot'a Sor
  13. RCA RP3715A Tuning Wheel Replacement: adım 13, 1 resimden 1.
    • Pull the battery terminal through the whole shown.
    FixBot'a Sor
  14. RCA RP3715A Tuning Wheel Replacement, Lift the digital screen: adım 14, 1 resimden 1.
    • First release the latch highlighted in the picture. Then grab the screen by the bottom and lift it up.
    FixBot'a Sor
  15. RCA RP3715A Tuning Wheel Replacement, Lift the top piece of motherboard: adım 15, 3 resimden 1. RCA RP3715A Tuning Wheel Replacement, Lift the top piece of motherboard: adım 15, 3 resimden 2. RCA RP3715A Tuning Wheel Replacement, Lift the top piece of motherboard: adım 15, 3 resimden 3.
    • Remove the motherboard from the frame using the illustration shown.
    FixBot'a Sor
  16. RCA RP3715A Tuning Wheel Replacement, Replacing the tuning wheel: adım 16, 1 resimden 1.
    • Lift up the gray tuning wheel and replace it with the new one.
    FixBot'a Sor
Sonuç
Alexander Trowell
222 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-5, Brown Fall 2014 USF Tampa, Team 10-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S10G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 46
Her zaman: 478
