Ana içeriğe geç
RCA Small Wonders Camcorder CC176 Viewfinder Replacement
Neye ihtiyacın var
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: adım 1, 3 resimden 1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: adım 1, 3 resimden 2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: adım 1, 3 resimden 3.
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: adım 2, 3 resimden 1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: adım 2, 3 resimden 2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: adım 2, 3 resimden 3.
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: adım 3, 2 resimden 1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: adım 3, 2 resimden 2.
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
Sonuç
Allison Baudoin
401 İtibar
4 adet Kılavuz yazıldı
Ekip
James Madison, Team 2-1, Allen Fall 2011 James Madison, Team 2-1, Allen Fall 2011 üyesi
JMU-ALLEN-F11S2G1
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 1,339
