Ana içeriğe geç
RCA Visys 25212 Handset Battery Replacement
Neye ihtiyacın var
  1. RCA Visys 25212 Handset Battery Replacement, Handset Battery: adım 1, 1 resimden 1.
    • Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
  2. RCA Visys 25212 Handset Battery Replacement: adım 2, 2 resimden 1. RCA Visys 25212 Handset Battery Replacement: adım 2, 2 resimden 2.
    • To remove the battery, gently pull up on the white connector located on the left side of the phone.
Sonuç
To reassemble your device, follow these instructions in reverse order. Make sure the battery connector is fully seated in the handset before replacing the back cover.
Sandy South
431 İtibar
4 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-3, Prince Winter 2015 Pasco Hernando, Team 5-3, Prince Winter 2015 üyesi
PHSC-PRINCE-W15S5G3
6 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 439
