Giriş
In order to replace parts inside the handset, it must be properly disassembled.
Neye ihtiyacın var
Place your thumb in the groove on the back of handset. Next, push down with your thumb and then slide the battery cover towards the bottom of the phone to remove the battery cover.
Remove the four screws, located at each of the corners within the back encasing, with a small Phillips head screwdriver.
Bir başkası bu kılavuzu tamamladı.
