Ana içeriğe geç
REL T5 Repaste transistors
    1. REL T5 Repaste transistors, Repaste heatsink and pads: adım 1, 3 resimden 1. REL T5 Repaste transistors, Repaste heatsink and pads: adım 1, 3 resimden 2. REL T5 Repaste transistors, Repaste heatsink and pads: adım 1, 3 resimden 3.
      • Re-apply thermal grease. Make sure to use an appropriate type. Hint: CPU paste is usually not the best solution.
      • Apply a little dot on the pad and place on the heatsink.
      • After speading it with a spatula, stick two together, and slide to distribute evenly.
      • Careful as to not damage the pads!
      FixBot'a Sor
      Yorum Ekle
    2. REL T5 Repaste transistors: adım 2, 1 resimden 1.
      • Apply a thin layer using the spatula on the transistors as well.
      • Mount the amplifier board back on its place.
      • Carefully set the transistors using the screws.
      • Fix the power board using its screws.
      • Check that there are no shorts between the transistors and the heatsink or backplate.
      • TODO image of mounted board
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jasper van Zuijlen
1.044 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 11
