Ana içeriğe geç
RIDGID BELT SANDER R2740 Timing Belt Replacement
Neye ihtiyacın var
  1. RIDGID BELT SANDER R2740 Timing Belt Replacement, Timing Belt: adım 1, 1 resimden 1.
    • Orientate the sander so that the timing belt housing is facing you.
    • Remove the 19mm T20 screw from the center of the timing belt housing.
  2. RIDGID BELT SANDER R2740 Timing Belt Replacement: adım 2, 1 resimden 1.
    • Remove the timing belt housing.
  3. RIDGID BELT SANDER R2740 Timing Belt Replacement: adım 3, 1 resimden 1.
    • Use your finger or a screwdriver to apply pressure on the belt away from the sander near one of the small wheels.
    • Rotate the large wheel while applying pressure until the timing belt is free from the wheels.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 940
