Ana içeriğe geç
RIDGID Belt Sander R2740 On/Off Switch Replacement
Neye ihtiyacın var
  1. RIDGID Belt Sander R2740 On/Off Switch Replacement, Power Cord: adım 1, 2 resimden 1. RIDGID Belt Sander R2740 On/Off Switch Replacement, Power Cord: adım 1, 2 resimden 2.
    • Orient the belt sander so that the RIDGID logo is facing you.
    • Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID Belt Sander R2740 On/Off Switch Replacement: adım 2, 2 resimden 1. RIDGID Belt Sander R2740 On/Off Switch Replacement: adım 2, 2 resimden 2.
    • Remove the two 16 mm T10 screws.
    • Remove the support bracket that holds the power cord into place.
  3. RIDGID Belt Sander R2740 On/Off Switch Replacement: adım 3, 3 resimden 1. RIDGID Belt Sander R2740 On/Off Switch Replacement: adım 3, 3 resimden 2. RIDGID Belt Sander R2740 On/Off Switch Replacement: adım 3, 3 resimden 3.
    • Lift the power cord from the resting grooves.
    • Rotate the switch so that the lock-on button is facing you.
    • Loosen the two 8 mm Phillips #3 screws.
    • Pull the two wires away from the switch.
  4. RIDGID Belt Sander R2740 On/Off Switch Replacement, On/Off Switch: adım 4, 1 resimden 1.
    • Undo the two screws on the backside of the switch with a Phillips #3 screw driver.
  5. RIDGID Belt Sander R2740 On/Off Switch Replacement: adım 5, 1 resimden 1.
    • Pull out the wires from the switch.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 796
