Ana içeriğe geç
RIDGID Belt Sander R2740 Tension Lever Spring Replacement
Neye ihtiyacın var
  1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement, Tension Lever Spring: adım 1, 1 resimden 1.
    • Turn the belt sander so that the RIDGID logo is facing you.
    • Flip the tension lever to the open position so that the tension on the spring is released.
    • Remove any sandpaper that is on the belt sander.
  2. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: adım 2, 3 resimden 1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: adım 2, 3 resimden 2. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: adım 2, 3 resimden 3.
    • Using the T20 Torx Screwdriver, remove the two (2) M4 X 19 mm screws on either side of the the belt tension release lever.
    • Remove the side plate to reveal the spring.
  3. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: adım 3, 2 resimden 1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: adım 3, 2 resimden 2.
    • Remove and replace the spring (OD 14.47mm X 38.1mm).
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 1,689
