Ana içeriğe geç
RIDGID R2740 Ball Bearing Replacement
Neye ihtiyacın var
  1. RIDGID R2740 Ball Bearing Replacement, Ball Bearing: adım 1, 2 resimden 1. RIDGID R2740 Ball Bearing Replacement, Ball Bearing: adım 1, 2 resimden 2.
    • Orient the belt sander so that the AirGuard Technology logo is facing you.
    • Remove the nine 19mm, two 51mm and one 32 mm screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID R2740 Ball Bearing Replacement: adım 2, 1 resimden 1.
    • Remove the assembly armature from the belt sander.
    • You may need to wiggle the assembly armature to remove it from the belt sander.
  3. RIDGID R2740 Ball Bearing Replacement: adım 3, 2 resimden 1. RIDGID R2740 Ball Bearing Replacement: adım 3, 2 resimden 2.
    • Use a hammer to pry the ball bearing from the assembly armature.
    • The ball bearing can be somewhat difficult to remove. You may need to apply WD-40 before removal.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,009
