Ana içeriğe geç
RIDGID R2740 Motherboard Replacement
Neye ihtiyacın var
  1. RIDGID R2740 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Unplug your device before proceeding..
  2. RIDGID R2740 Motherboard Replacement: adım 2, 1 resimden 1.
    • Orient the sander so the Air Guard logo is facing you.
    • Remove the single Torx TR20 screw.
  3. RIDGID R2740 Motherboard Replacement: adım 3, 2 resimden 1. RIDGID R2740 Motherboard Replacement: adım 3, 2 resimden 2.
    • Orient the device with the left side face up.
    • Using a Phillips #1 bit, unscrew the 3 screws which hold the internal casing in place.
    • Gently remove the belt.
    • Using the Torx TR10 bit, unscrew the 10 screws which hold the external casing in place.
  4. RIDGID R2740 Motherboard Replacement: adım 4, 1 resimden 1.
    • Gently pull up on the motherboard chip set, pulling it directly from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 628
