Ana içeriğe geç
RIDGID R32104 Motor Bearings Replacement
Neye ihtiyacın var
  1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: adım 1, 2 resimden 1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: adım 1, 2 resimden 2.
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Bearings Replacement: adım 2, 2 resimden 1. RIDGID R32104 Motor Bearings Replacement: adım 2, 2 resimden 2.
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Bearings Replacement: adım 3, 1 resimden 1.
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: adım 4, 3 resimden 1. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: adım 4, 3 resimden 2. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: adım 4, 3 resimden 3.
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Bearings Replacement: adım 5, 2 resimden 1. RIDGID R32104 Motor Bearings Replacement: adım 5, 2 resimden 2.
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Bearings Replacement: adım 6, 2 resimden 1. RIDGID R32104 Motor Bearings Replacement: adım 6, 2 resimden 2.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Bearings Replacement: adım 7, 2 resimden 1. RIDGID R32104 Motor Bearings Replacement: adım 7, 2 resimden 2.
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: adım 8, 2 resimden 1. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: adım 8, 2 resimden 2.
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Bearings Replacement, Gear Box: adım 9, 2 resimden 1. RIDGID R32104 Motor Bearings Replacement, Gear Box: adım 9, 2 resimden 2.
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: adım 10, 3 resimden 1. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: adım 10, 3 resimden 2. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: adım 10, 3 resimden 3.
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
  11. RIDGID R32104 Motor Bearings Replacement, Motor Bearings: adım 11, 1 resimden 1.
    • The bearings are located on the opposite end of the motor rotor, from where the fan blade was.
    • Carefully remove the motor bearings from the motor rotor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lucas Pimentel
1.010 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Julie Spring 2019 UMass Dartmouth, Team S5-G1, Julie Spring 2019 üyesi
UMASSD-JULIE-S19S5G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 508
