Ana içeriğe geç
RIDGID R32104 Motor Brush Replacement
Neye ihtiyacın var
  1. RIDGID R32104 Motor Brush Replacement, Motor Brush: adım 1, 2 resimden 1. RIDGID R32104 Motor Brush Replacement, Motor Brush: adım 1, 2 resimden 2.
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Brush Replacement: adım 2, 2 resimden 1. RIDGID R32104 Motor Brush Replacement: adım 2, 2 resimden 2.
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Brush Replacement: adım 3, 1 resimden 1.
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucas Pimentel
1.010 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Julie Spring 2019 UMass Dartmouth, Team S5-G1, Julie Spring 2019 üyesi
UMASSD-JULIE-S19S5G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 791
