Giriş
A faulty motor rotor can cause sparking and other serious issues with the saw. This is a guide to replace the motor rotor. Although it is an intensive project, it is doable and all you need are a Torx T20 screwdriver, a Torx T50 screwdriver, and a flathead screwdriver.
Neye ihtiyacın var
Place down the Worm Drive Saw on a sturdy surface.
The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
Wiggle out the gear box to easily gain access to the motor rotor.
Once taken out, the motor rotor is easily accessible.
The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
Carefully remove the motor rotor from the device.
Bir başkası bu kılavuzu tamamladı.
