Ana içeriğe geç
RIDGID R32104 Saw Blade Replacement
Neye ihtiyacın var
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: adım 1, 1 resimden 1.
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: adım 2, 2 resimden 1. RIDGID R32104 Saw Blade Replacement: adım 2, 2 resimden 2.
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: adım 3, 1 resimden 1.
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: adım 4, 1 resimden 1.
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucas Pimentel
1.010 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Julie Spring 2019 UMass Dartmouth, Team S5-G1, Julie Spring 2019 üyesi
UMASSD-JULIE-S19S5G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 916
