Ana içeriğe geç
RIDGID R32104 Trigger Replacement
Neye ihtiyacın var
    1. RIDGID R32104 Trigger  Replacement, Trigger: adım 1, 1 resimden 1.
      • Turn off your saw and unplug before starting.
      • Place the Worm Drive Saw down and adjust the base plate, so that way the main housing assembly and handle set is easily accessible.
      FixBot'a Sor
      Yorum Ekle
    2. RIDGID R32104 Trigger  Replacement: adım 2, 2 resimden 1. RIDGID R32104 Trigger  Replacement: adım 2, 2 resimden 2.
      • Using the Torque 20 screwdriver, remove the twelve 3/10 cm screws holding the handle set together.
      FixBot'a Sor
      Yorum Ekle
    3. RIDGID R32104 Trigger  Replacement: adım 3, 2 resimden 1. RIDGID R32104 Trigger  Replacement: adım 3, 2 resimden 2.
      • Carefully remove the handle set from the main housing assembly.
      FixBot'a Sor
      Yorum Ekle
    4. RIDGID R32104 Trigger  Replacement: adım 4, 3 resimden 1. RIDGID R32104 Trigger  Replacement: adım 4, 3 resimden 2. RIDGID R32104 Trigger  Replacement: adım 4, 3 resimden 3.
      • Place the Worm Drive Saw on its side to help remove the trigger.
      • Use the Torque 20 screwdriver to remove the single 3/10 cm screw that attaches the trigger switch to the handle set.
      FixBot'a Sor
      Yorum Ekle
    5. RIDGID R32104 Trigger  Replacement: adım 5, 2 resimden 1. RIDGID R32104 Trigger  Replacement: adım 5, 2 resimden 2.
      • Use the Phillips 2 screwdriver to remove the four 3/10 cm screws holding the trigger and four wires, from the main housing assembly, in place.
      FixBot'a Sor
      Yorum Ekle
    6. RIDGID R32104 Trigger  Replacement: adım 6, 1 resimden 1.
      • Remove the trigger switch and trigger from the handle set.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lucas Pimentel
1.037 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Julie Spring 2019 UMass Dartmouth, Team S5-G1, Julie Spring 2019 üyesi
UMASSD-JULIE-S19S5G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 746
