Ana içeriğe geç
RIDGID R84015 X2 Disassembly
Neye ihtiyacın var
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: adım 1, 2 resimden 1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: adım 1, 2 resimden 2.
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: adım 2, 1 resimden 1.
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: adım 3, 2 resimden 1. RIDGID R84015 X2 Disassembly: adım 3, 2 resimden 2.
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: adım 4, 1 resimden 1.
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: adım 5, 1 resimden 1.
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: adım 6, 1 resimden 1.
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: adım 7, 1 resimden 1.
    • Make sure plastic is not broken and switch is not stuck.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Brian
97 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G48
6 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 31
Her zaman: 13,566
