Ana içeriğe geç
RIDGID R84015 X2 Speed Switch Replacement
Neye ihtiyacın var
  1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: adım 1, 2 resimden 1. RIDGID R84015 X2 Speed Switch Replacement, RIDGID R84015 X2 Case Removal: adım 1, 2 resimden 2.
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Speed Switch Replacement: adım 2, 1 resimden 1.
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Speed Switch Replacement: adım 3, 2 resimden 1. RIDGID R84015 X2 Speed Switch Replacement: adım 3, 2 resimden 2.
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Speed Switch Replacement, Speed Switch: adım 4, 1 resimden 1.
    • Locate small metal bar above plastic part of drill.
    • Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
  5. RIDGID R84015 X2 Speed Switch Replacement: adım 5, 2 resimden 1. RIDGID R84015 X2 Speed Switch Replacement: adım 5, 2 resimden 2.
    • If the bar moves, next check the small plastic switch that is numbered 1 and 2.
    • Make sure the small tabs on the underside of the switch that move the bar are intact.
    • Replace switch as needed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Evan Long
262 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G48
6 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 3,639
