Giriş
The speed (1-2) Switch is either stuck or won't change speed of rotation.
Remove the backplate.
Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
Locate small metal bar above plastic part of drill.
Attempt to move bar back and forth. If it wont move, try to move it while rotating the chuck. If it still will not move, there is a problem with the gears. For help see the Planetary Gear Replacement Guide
2 farklı kişi bu kılavuzu tamamladı.
