Giriş
Use for a diagnosed wiring problem.
Neye ihtiyacın var
Remove the backplate.
Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
Use a multimeter set above 18V DC to check electrical connections where wires meet drill, switch, or battery terminal.
After soldering sand off jaged solder then wrap with electrical tape
Tin the broken wires with Rosen core solder and do not overuse the solder. Heat one side pretinned wire and place the other pretinned wire on that till the solder melts together. Remove iron and cool and you should have a quality repair. Don’t forget to add heat shrink before doing the connection.
Bir başkası bu kılavuzu tamamladı.
