Ana içeriğe geç
RIDGID R860052 Motor Replacement
Neye ihtiyacın var
  1. RIDGID R860052 Motor Replacement, Motor: adım 1, 2 resimden 1. RIDGID R860052 Motor Replacement, Motor: adım 1, 2 resimden 2.
    • Remove the battery from the drill before you begin.
    • Use a T10 Torx screwdriver to remove the ten screws on the information label side of the drill.
    • These ten screws are 19 mm long.
  2. RIDGID R860052 Motor Replacement: adım 2, 1 resimden 1.
    • Lift off and remove the cover with the informational label.
  3. RIDGID R860052 Motor Replacement: adım 3, 3 resimden 1. RIDGID R860052 Motor Replacement: adım 3, 3 resimden 2. RIDGID R860052 Motor Replacement: adım 3, 3 resimden 3.
    • Remove the switch assembly, chuck, and motor from all drill covers.
  4. RIDGID R860052 Motor Replacement: adım 4, 2 resimden 1. RIDGID R860052 Motor Replacement: adım 4, 2 resimden 2.
    • Twist the chuck and motor in the opposite direction and gently pull them apart.
  5. RIDGID R860052 Motor Replacement: adım 5, 3 resimden 1. RIDGID R860052 Motor Replacement: adım 5, 3 resimden 2. RIDGID R860052 Motor Replacement: adım 5, 3 resimden 3.
    • Desolder the black and red wires from the motor.
    • Replace motor and resolder the black and red wires back onto the motor.
    • Be aware of the heat level of the metal part on the soldering tool.
Sonuç
Andrea Hernandez
204 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S18-G4, Lore Winter 2019 UC Davis, Team S18-G4, Lore Winter 2019 üyesi
UCD-LORE-W19S18G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 585
