Ana içeriğe geç
ROYALAXE R68 TKL Key Switches Replacement
Neye ihtiyacın var
  1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: adım 1, 2 resimden 1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: adım 1, 2 resimden 2.
    • Unplug the keyboard from its power source.
  2. ROYALAXE R68 TKL Key Switches Replacement: adım 2, 1 resimden 1.
    • Remove all keycaps with the keycap puller.
    • You can line up the keycaps in order or take a picture of your keyboard to make it easier to put them back on at the end.
  3. ROYALAXE R68 TKL Key Switches Replacement: adım 3, 2 resimden 1. ROYALAXE R68 TKL Key Switches Replacement: adım 3, 2 resimden 2.
    • Clean the keyboard using a compressed air duster and a small brush or cotton swab.
    • You can also clean your keycaps by soaking them in a bowl with water and soap for about 30 minutes.
  4. ROYALAXE R68 TKL Key Switches Replacement: adım 4, 2 resimden 1. ROYALAXE R68 TKL Key Switches Replacement: adım 4, 2 resimden 2.
    • Remove the switches with the switch puller.
    • Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
    • Taking out the switch by pulling horizontally could damage the switch.
  5. ROYALAXE R68 TKL Key Switches Replacement: adım 5, 3 resimden 1. ROYALAXE R68 TKL Key Switches Replacement: adım 5, 3 resimden 2. ROYALAXE R68 TKL Key Switches Replacement: adım 5, 3 resimden 3.
    • Make sure the copper part of the switch faces you when you try to insert the switch.
    • Insert the key switch as straight as possible and press down gently until you hear a click.
    • If you fail to line it up, it will bend the copper part under the switch. This will permanently damage the switch.
  6. ROYALAXE R68 TKL Key Switches Replacement: adım 6, 2 resimden 1. ROYALAXE R68 TKL Key Switches Replacement: adım 6, 2 resimden 2.
    • Place keycaps in their respective position.
    • Make sure all keys are operating well.
    • Enjoy your new switches!
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Angie
163 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 45
Her zaman: 373
