Ana içeriğe geç
RTX 3070 VENTUS 2X OC GPU FAN Replacement
Neye ihtiyacın var
  1. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Grab your tools and prepare: adım 1, 1 resimden 1.
    • Clear your workspace to prevent screws from going missing.
  2. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Remove GPU shroud: adım 2, 2 resimden 1. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Remove GPU shroud: adım 2, 2 resimden 2.
    • Remove the screws that are holding your shroud in place(may differ from card to card)
  3. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, removal of shroud: adım 3, 1 resimden 1.
    • Remove shroud from heatsink
    • Be careful of fan wires when removing shroud
    • In some models the fan are screwed into the heat sink. In those models just remove the shroud for easy access to the fan
  4. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, gpu fan cable: adım 4, 2 resimden 1. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, gpu fan cable: adım 4, 2 resimden 2.
    • Remove the gpu cable and it leave behind the bare heatsink
  5. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan screw: adım 5, 2 resimden 1. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan screw: adım 5, 2 resimden 2.
    • Remove the screws that are holding the fans in place
  6. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan removed: adım 6, 2 resimden 1. RTX 3070 VENTUS 2X OC  GPU FAN Replacement, Fan removed: adım 6, 2 resimden 2.
    • Get your replacement fan and reverse the order for reassembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
fareast00
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 50
Son 30 gün: 285
Her zaman: 6,552
