Giriş
Having problems with GPU thermals or a bad GPU fan? This guide is for you
Neye ihtiyacın var
Clear your workspace to prevent screws from going missing.
Remove the screws that are holding your shroud in place(may differ from card to card)
Remove shroud from heatsink
Be careful of fan wires when removing shroud
In some models the fan are screwed into the heat sink. In those models just remove the shroud for easy access to the fan
2 farklı kişi bu kılavuzu tamamladı.
