Ana içeriğe geç
RYDIS H68 Pro Side Brush Motor Replacement
Neye ihtiyacın var
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: adım 1, 2 resimden 1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: adım 2, 1 resimden 1.
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: adım 3, 3 resimden 1. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: adım 3, 3 resimden 2. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: adım 3, 3 resimden 3.
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: adım 4, 3 resimden 1. RYDIS H68 Pro Side Brush Motor Replacement: adım 4, 3 resimden 2. RYDIS H68 Pro Side Brush Motor Replacement: adım 4, 3 resimden 3.
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: adım 5, 3 resimden 1. RYDIS H68 Pro Side Brush Motor Replacement: adım 5, 3 resimden 2. RYDIS H68 Pro Side Brush Motor Replacement: adım 5, 3 resimden 3.
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: adım 6, 1 resimden 1.
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: adım 7, 1 resimden 1.
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: adım 8, 1 resimden 1.
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: adım 9, 1 resimden 1.
    • The side brush motor can now be removed by lifting it up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
jude auguste
108 İtibar
1 Kılavuz yazıldı
Ekip
USFT-Lacy-S17S005G2 USFT-Lacy-S17S005G2 üyesi
Repair Café
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 584
